I have the latest version of the Edge Juice with Atitude for a Duramax LB-7. I only used this unit a month before I sold the truck. I have the overhead ATS monitor mount for it that is included. The EGT probe is brand new.
$500.00 plus shipping
Donnie Book
dbook101@comcast.net
Here is Edge's info on it:
KEY FEATURES:
• 5 on-the-fly Adjustable Power Levels
• Touch-of-a-Button Control
• Additional 150 HP and 350 ft lb Torque
• Increases Fuel Economy*
• Greatly Improves Driveability and Performance
• Monitors Various Transmission Functions
The Edge Juice/Attitude is a highly sophisticated package capable of dramatically improving your Duramax’s driveability, towing, mileage and, most importantly, POWER.
Using factory-style connections in just thirty minutes you can add five levels of adjustable power ranging from 40-150 horsepower and increase torque up to 350 ft. lbs. The Juice greatly improves responsiveness and driveability, while at the same time increasing fuel economy.
The Juice communicates along the engine’s CAN-BUS data stream, from which it receives vital engine, transmission, and fuel system information. This enables the Juice to provide smooth and precise power curves that are truly custom, rather than just an offset from stock.
The Juice also monitors the transmission slippage when the torque converter clutch is engaged. The level of additional power is decreased if any slippage is detected. This prevents damage from being caused to the transmission, and also prevents the power train from erroneously generating fault codes and entering “limp mode”.
The Juice also limits the amount of power increase during transmission shifts when the torque converter clutch is engaged and also when the torque converter clutch is being engaged. This allows the torque converter clutch to engage without slipping.
When used in conjunction with the Attitude monitor you can control the five power levels on-the-fly from inside your truck. The Attitude displays all the information a complete set of gauges would and will automatically monitor and display exhaust gas temperature (EGT), turbo boost and transmission slip and de-fuel the engine to prevent excessive EGT, boost levels or transmission slippage. It also displays 0 – 60 times, quarter mile times and actual speed if you are using non-stock tires as well as a host of other parameters.
The Juice communicates directly with the engine’s ECM, from which it receives vital engine and fuel system information. This enables the Juice to provide smooth and precise power in real time under any driving condition. Imagine, within minutes you get incredible power gains, an increase in mileage and the equivalent of a complete set of gauges with one simple installation!
The following power gains are representative of an actual test vehicle. These gains were measured on a SuperFlow Dyno at an altitude of 4400 ft above sea level, and represent power delivered to the rear wheels of the test truck. The only modification made to the test truck was the addition of the Edge Juice module. Power gains may vary based on vehicle and geographical location.
Level 0: Stock
Level 1: 40 Horsepower - 150 Foot Pounds of Torque
Level 2: 60 Horsepower - 180 Foot Pounds of Torque
Level 3: 75 Horsepower - 200 Foot Pounds of Torque
Level 4: 90 Horsepower - 250 Foot Pounds of Torque
Level 5: 125 Horsepower - 325 Foot Pounds of Torque
Level 6: 150 Horsepower – 350 Foot Pounds of Torque
Hot Unlock Code plus additional fee required for level 6. For pricing information and to get the unlock code you must complete a waiver located under product updates.
Your Attitude monitor allows you to monitor the performance of your engine’s vital engine components and output values. The following parameters can be displayed on the main Attitude screen (maximum 4 at one time):
• Boost
• EGT
• Barametric PSI
• Speed MPH
• Engine Coolant Temperature
• Gear
• Intake Air Temperature
• Load%
• Slip %
• Transmission Temperature
• Throttle%
• Turbo Boost PSI
• RPM
• Backdown
That Attitude can sound an alert when certain engine parameter levels are met. The following alerts are available:
• EGT
• Boost
• Engine Temp
• Speed
Keep track of your performance by recording maximum/minimum for a variety of parameters including:
• Max Engine Temp F
• 0-60 times
• ¼ mile times
• Max RPM
• Max Speed
• Backdown %
KEY FEATURES:
Level 0: Stock
• Boost
• EGT
• Barametric PSI
• Speed MPH
• Gear
• Load%
• Slip %
• Throttle%
• Turbo Boost PSI
• RPM
• Backdown
• EGT
• Boost
• Engine Temp
• Speed
• Max Engine Temp F
• 0-60 times
• ¼ mile times
• Max RPM
• Max Speed
• Backdown %
Donnie Book
KEY FEATURES:
Level 0: Stock
• Boost
• EGT
• Barametric PSI
• Speed MPH
• Gear
• Load%
• Slip %
• Throttle%
• Turbo Boost PSI
• RPM
• Backdown
• EGT
• Boost
• Engine Temp
• Speed
• Max Engine Temp F
• 0-60 times
• ¼ mile times
• Max RPM
• Max Speed
• Backdown %
KEY FEATURES:
Level 0: Stock
• Boost
• EGT
• Barametric PSI
• Speed MPH
• Gear
• Load%
• Slip %
• Throttle%
• Turbo Boost PSI
• RPM
• Backdown
• EGT
• Boost
• Engine Temp
• Speed
• Max Engine Temp F
• 0-60 times
• ¼ mile times
• Max RPM
• Max Speed
• Backdown %
