Edge High Rise Hood
Hill Topper
$240 plus shipping EST. ($75)
Revy Polaris Edge Hood
Used Light Weight Hood
This hood was used as a display hood at many shows around the country.It is in good shape but not brand new It is great for running aftermarket pipes due to the fact is has extra height built in to it
Revy Hoods weigh as little as 8lbs.
Revy hoods are easily repaired! In the event you crack the hood, you can get a fiberglass repair kit at most hardware/automotive stores. The repair instructions are on the can of resin to help you through the process.
Use the hood as a replacement for a stock hood that has been destroyed. Stock hoods are made of injection-molded plastic that is not easily repaired.
Install a Revy Hood on your new sled and put the stock hood away. When you sell the sled, put your “new” stock hood back on your sled.
Revy Edge Hoods come with a built in Hi-Rise (1-1/2”) to accommodate aftermarket pipes.
Revy Edge Hoods also can be fitted with PIAA headlights ($120.00) for that custom MOD look.
Revy Hoods come in standard colors of Black and White.
Revy Edge Hoods also come with hinge mounts if you want your hood to be hinged.
Call with any Questions Jason 612-306-8421
This hood needs tobe picked up at your local Gray Hound Station!!! This is the least costly way to ship the hood!
