N
01 800 edge
throtle / Kill switch block $ 25.00
throttle cable $ 5.00
ignition switch w/ key $ 10.00
choke cable $ 5.00
coil with plug wires $ 20.00
Torsion bar $ 5.00
Tunnel Heat Exchangers $ 15.00
exhaust pipe stock $ 45.00
exhaust silencer stock $ 15.00
brake hose $ 5.00
Speedo $ 15.00
Tach $ 20.00
Hood - red w/ graphics no cracks $ 100.00
steering post $ 10.00
Head Light Assy. $ 15.00
wire harness $ 25.00
Steering linkage $ 15.00
Brake caliper $ 10.00
belt Guard $ 5.00
speedo pick up $ 5.00
jack shaft with disk $ 5.00
Drive Shaft with Drivers $ 15.00
speedo cable $ 5.00
spindles and steering arms $ 15.00
primary spring blue with white stripe $ 5.00
primary spring blue with green stripe $ 5.00
primary spring black #3121 100/340 $ 5.00
Pro X seat 02 small rip by trunk $ 75.00
02 600 Edge
Handle bars stock $ 5.00
brake hose $ 5.00
recoil assy. $ 25.00
Y pipe $ 20.00
Carb rack TM38 $ 60.00
carb boots 2 $ 15.00
Reed cage and reeds set of two $ 20.00
pull handle $ 2.00
rectifier $ 5.00
clutch weights 10-62 set of three $ 20.00
clutch weights 10-62 set of two $ 10.00
rear axle and wheels $ 5.00
upper boggie wheels $ 5.00
front swing arm $ 15.00
rear swing arm $ 15.00
Tach $ 15.00
06 600 RMK
tunnel extension and heat exchanger $ 40.00
front heat exchanger $ 15.00
coolant tank $ 5.00
Brake Caliper assembly $ 15.00
Rox handle bar pad $ 5.00
RMK handle bars with mountian handle $ 15.00
steering linkage $ 15.00
All parts are list plus shipping from 49417
PM me here or email at nicholsgh@att.net
choke cable $ 5.00
Torsion bar $ 5.00
brake hose $ 5.00
Speedo $ 15.00
Tach $ 20.00
belt Guard $ 5.00
speedo cable $ 5.00
02 600 Edge
brake hose $ 5.00
Y pipe $ 20.00
pull handle $ 2.00
rectifier $ 5.00
Tach $ 15.00
06 600 RMK
coolant tank $ 5.00
