Edge 16 inch wide track thoughts
Did it...in a word..SUCKS I did a 16x162 3" paddle...killed the turning and side hilling, stick with a good 2.5 15 wide. Took track off after 4 rides.
Last year I had the stock 159x15x2 poo series 4 track, stock skis and stance. I could throw the sled around pretty easily. It was playful but still long enough to climb pretty well.
This year I have a 174x16x2.5, narrowed radius rods 1" each (2" narrower ski stance) in hopes of offsetting the wider track, and upgraded to Gripper skis. Its significantly less playful, but climbs like a motherf. I wanted better climbing, as I usually use my sled for snowboarding access, but its not as fun as the old setup if you're sidehilling or just carving around.
If I did it over (the 174", or any track upgrade for that matter) I'd go with a 15" wide. The 16" wide seems to rub on the sides during cornering too.
well here is what i was going to do. 151 inch 16 track, wahl anti sprockets. use the 144 suspension and move it back. Put an offset axle in backwards and use 8 inch slydogg fan blade wheels. 8 inch drop brackets.
I want to get away from trenching.
ideas? thoughts?
I went from a 144" x 2" to a 159" x 2.125" (15 wide)and it was the best thing I did to that rmk. No more trenching and still easy to maneuver. I'm only 170 lbs. stock drivers and rear idlers. lowered the gears and changed
the springs and helix.
Yeah I will say it was like riding a tractor around....climbing and brakeing very good..but thats not why I ride....
