08 700 rmk TPS and idle voltage are spot on, yet sled is not running right. Idle is at 2200 rpm and it sputters at 5500 rpm and at 6800rpm. The sled ran fine before I started adjusting TPS and idle voltage, except for a low idle and troubles going in and out of reverse. These were the problems that I was trying to correct. Does it take time for the ECU to recognize these changes? I am running the sled at sea level in the garage. Does anyone think the sputter may go away once I get to the hill? Other ideas??
