ecu code 17 on 09 m-8
riding in the back yard warm motor throws code 17 ,exhaust sensor code, shut off motor start 30 minutes later then no code, checking the conecter with an omhmeter it shows continuity. if the sensor is bad wouldn't it throw a code on cold start? then i called dealer he said if the sensor is bad they would have to replace the sensor and reset/remove the code. any advice or suggestions
