ECU code 15
Bendy
Does anyone know what code this is? Where I can find code descriptions? It came on going up the trail. Stopped, shut the engine down and cycled the key and restarted. It came on again and that was the last time it flashed the code. It seemed to run normal.
I figured...
it would be under the hood somewhere. I was going to look, but it never came back a third time. I'll check for the decal when I do my pre-ride inspection for the next trip.
code 15 is a o2 sensor. Mine will come on sometimes if I am going slow and lugging the engine down. If I open up the throttle for a bit it goes away. The other times it could be to much leaded race gas.
I was thinking the same thing!
Lead in the Av gas. I run higher boost and you just never know what you're getting at the pump. My riding buddy tested some fuel after a melt down on his machine. 38 points! It must have been mostly water?
