ECM Water problem Update
I made a makeshift waterproofing cover for my ECM and went to try it out today. My sled didn't really run right from the start and my odometer was still not working. It seems like my entire electrical system went down. My brake light, odometer, reverse button don't work, my tach lights don't work. the gauge for the tach shows rpm's and my lights work but i think thats about it.
I'm thinking my dpm isn't working cuz my sled is running super rough and seems like it putting too much gas into it but I really don't know. What could this be. Is my ECM shot? What could this be?
TPS connector maybe??
My 06 800 did something similar and took it to the dealer and they replaced a three pole connector that commonly breaks the poles and causes all kinds of beeping and false codes. BRP-TPS Connector Housing part # is 515176176.
Xtreme Powersports sells the Throttle Position Sensor and other connectors so check all of these connectors and maybe one of them is shorting out or broken.
http://216.37.204.206/xtremepowersports/Skidoo_OEM/Skidoo.asp?Type=13&A=725&B=44
what year of sled? my '08 XP shorted the tail light wires where they come out of the heat exchangers and did a lot of the same things.
Its an 06 summit x 800. Its not just the brake light, its the odometer, my reverse button, the lights on the dashboard, electric start... Would this type of thing happen if the ECM went bad?
