Those who use a ebc .do you like them?are they worth 400 bucks?
Mine is great, except for the 3-4 times I have had the lines and or EBC ice up. Then it sucks.
Have you had this problem, or just assuming that it could happen?IMO it is a combination of a chunk of line being outside of the hood, and the very small id tubing that is used. It does not take much moisture/ice to clog up 1/16" id tubing or whatever it is.
The other problem is that the EBC is what sends an electronic boost signal to the boondocker box. When the EBC or line is iced up, your over boosting, and adding NO BOOST FUEL......bummer.
If you run it on your cutler kit, it would not be as big of a deal as the EBC is only controlling boost, and not supplying boost reference to your fuel box.
But don't get me wrong, I think the EBC is a sweet little unit.
On my sled, I think the water is coming from snow that falls through the hood vent/holes below the headlight's that turns into water vapor and gets pushed down the lines when the sled is restarted.
I dont think many others have had this problem, but it is something to watch for for sure.
But again, if you are only using it as a boost controller on other brand kits, that sense boost pressure from a line off the air box, you have far less to worry about.
hey joe, where did your cool avatar go???I've had the same problem that Breeze is having. It led to a pretty nasty crash last season. When the line ices up the sled quits sensing boost and bogs. Depending on how much ice is in it, it will sometime bog then clean out then bog again. It almost ruined a day for me until I figured out the problem. I now carry a clean piece of line with me and when I get a chance I blow the moisture out of line that's on there. I've had more issues when the sled is left in a trailer or sitting out over night. Usually if the sled is in the garage and thaws out and drys before the next ride it's fine. It's not a huge problem but it does annoy me. The lower on your bars you mount it the better, I doubt you would have a problem if you keep the 1/16" line under the hood. The line I use is clear so you can see the ice forming. If you have a piece of black line I would replace it so you can at least watch for an issue. If I were to do it all over again, I doubt I would go with an EBC. I would ditch the one I have but my fuel booster board is inside it and I would have to completely redo my fuel system to dump the EBC. Depending on how this weekends ride goes, I might have a smokin deal available on a slightly used EBC.
