I have a 2009 Assault with a bd pg turbo w/mini intercooler. I can not get the sled to quit going into det on the big end. I have 2010 update w the 2009 programing. Im running straight 110 race fuel, have a turbo dome head from fastrax. I'm only running 7-8 pounds of boost so the ebc reads. My starting numbers are alot higher then what bd says to start with. But it doesn't mater if i lean it out or rich it up it still pops and bangs when it spools up. The ebc reads weird things and the control box either goes blank and still back lit or has nnnnnnnn with a lines under the n's. Talk to bd and they said they never heard of it and it must be a bad ground... I have checked and tested every ground four times. I've been fighting this now for 3 weeks with no luck. Any advice would be great. Also this is doing it w the ebc set at 0. If i change alt+0=0 to 5 or anything it flat doesn't run...
