Got my new rails.
Is it easier to remove the entire rear skid assembly or to replace one rail at a time on the sled?
Skid out for sure.
Nice! Who makes them Ice Age? What was the benifit of the swap? Thank you![]()
Ya pulling the skid was definatly the way to go. Thanks
Ya these are IgeAge.
Benefit is these ones aren't bent all to hell. lol
If anyone is looking for rails, IgeAge gets my vote. Decent price ($700 with shipping and customs fees to Canada)
Only hiccup was my rail stiffeners are on "backorder" (so they say) which no one decided to tell me until I found out when I opened the box and they weren't in there.
Other than that, they're nice rails and quick shipping.
Mine were 350 plus shipping. And pow coat $60
Yeah my stockers broke at the front torque arm mount.
Ice age min. 8" wheel
Can order for 9 or 10
Yes they're pre-drilled for Stock scratchers. Also pre-drilled for The stock front bogey wheel/mount
But I did have to drill one of the holes out on each rail to a bigger size to fit the stock cross shaft in the rear.
Went with the 8" plastic wheel cause they were cheap ($35ea.) and i wanted black anyways, they dont make a plastic wheel in 9" didn't see a 10" option but I'm sure they would built it if you wanted. (stock wheels are 7 1/4")
They come with hyfax included from IceAge
I didn't compare them side by side.
Im replacing my rails right now. And I think I'm running into the issue you are talking about. Are you talking about the bar that is about 8" in front of the rear axle? My rails are not drilled for the bolts. Are they supposed to have the correct bar and bolts and they didnt put it in the box? They didnt tell me **** about that.
Yes you do have to drill out the rear hole approximately 8'' from the rear axle. The existing hole is too small diameter. I drilled one size bigger than the bolt, I do believe 13/32. Other than that, everything is same as OEM.
