e9 on innovate efr
turbonium
I am intermittently getting e9 code on my Afr. Anyone know what that code is?
Merry Christmas
More E9 Codes today
I received the E9 code more often today. The engine was stumbling at idle after long pulls. It seemed like it was loosing power. The dash lights would go out. I would let it cool off and it ran fine until it got hot again. :noidea:
Try turning hand warmers off , if it still does it check the power and grounds going to the afr gauge if all good .. then I would lean towards voltage reg.
Mine does the same thing. I blip the throttle then it all comes back on, then will return to that after a few seconds. Been living with it so far but would like to know the fix if someone has figured this out.
Im also leaning towards voltage regulator.
What year are your guys' sleds? Mine is a 2011. From what I can tell the 11s and 12s had a dc regulator. (On the clutch cover by the oil tank) However the 13s and 14s did not have this regulator, according to the parts diagrams.
All the years have an ac/dc regulator (mounted on the cross-shaft above the pipe)
Im guessing the regulator possibly needing replacing is the DC one...
