E-Start installation instructions, 2013 PRO 800?
Hello,
Does anyone know if there are installation instructions to be found online? Just want to look at them before I get my kit so I can be prepared and hopefully make the install a bit smoother if I can study them ahead of time.
Thanks,
-John
I would not worry too much about it. It is a pretty easy install and the directions are easy to follow. Read over them a couple times before you start and you are good to go. Should only take 2-3 hours depending on your abilities. There will be some left over parts though as the kit it for more than 1 modle. Take your time and read twice so you can install once.
Am I understanding correctly that the e-start accessory kit comes with a new/unloaded primary clutch that a person needs to transfer the primary spring and weights? If yes, I wonder why Poo chooses to not simply supply a ring gear to add to the stock clutch and reduce the cost of the e-start kit....
Thanks,
-John
I received and installed my e-start kit, it went pretty smooth/easy. I do have 1 question regarding 1 wire that the installation instructions did not make reference to....
Can someone look at their e-star PRO and tell me if you have 2 wires going to the negative terminal on the battery? There will obviously be the large gauge wire but also there is a small guage brown wire with plastic corrugated tubing on it, this is the one I could not find reference to in the installation instructions) that comes from the main e-start wire harness that has a ring terminal connector on it(item #9 in the attached pic, specifically the bottom wire that has the ring terminal on the end of it). It has extra length to it an can/will easily reach the negative post on the battery. I cant see anywhere else that it would go..? Can someone confirm?
Thanks much!
-John
Thanks,
-John
Because they balance the ring gear with the fixed half of the clutch.
