tested stock, our 860r big bore, single pipes, y pipes, reeds, twin pipes, heads.
I was with CJ motorsports at Dynotech last December. We were the 9th 800R in a row to go on the dyno.
Jim told us that on these 800R's so far, he had to "make a run at the pipe" do warm up runs to get the pipe as hot as he could before a full pull. When the pipe temperature got near equilibrium, could not get hotter then the engine would make an honest 150 hp, then let off the throttle and do the 2nd full pull, it would make 151~153hp after a 6~9 second run.
Jim mentioned to us that for a normal trail rider who runs on the trail, he can see the pipe temperature during riding being less than what he would run there on the dyno - the engine probably won't make over 145hp. The other runs he did with cooler pipe temperatures were around 144hp.
With 91 octane on my own 08XP800, made 137hp on 1st pull and 147 after a run at the pipe.
Silly question...but if the hotter the pipe is the more HP the 800R produces, why is it that on the hill it feels like the sled pulls a lot harder and climbs higher if you let things cool off for a bit before hitting the hill again? Is it because the clutch is hot and shifts better when cooler ?
I have noticed this on my '02 Summit 800 & my '08 XP
As pipe temperature increases, hp increases, torque decreases.
as pipe temperature cools, hp decreases, torque increases.
Far as that "feeling" goes, I don't know. I only can recall principles from engine part vendors like rkt or bjohn, supertuner...etc.
