W wrang New member Feb 24, 2011 #1 Hello. This is a 2011 M8 with BD PG turbo. The control box uses Duty Cycles to change from LO MD HI. Is it possible to use TPS signal to change from LO MD HI??? How do I wire this up? Which meny in the control box do I change to TPS?
S snwman77 Banned Feb 24, 2011 #2 You might want to read your paper work that explanes how the BD box works a coulpe more times, im sure it will help you understand. Last edited: Feb 24, 2011
H hyperduc Free Member Feb 24, 2011 #3 little backward there... Duty cycle is manipulated based on TPS and RPM, Lo, Med, and Hi are not referring to the duty cycle itself, rather the tps range or the rpm range in which you want to modify the duty cycle.
