Duramax rough idle??? fuel treatment?
lly injectors aren't covered for 7/200,000, it is the lb7 that's covered. Check the harness that goes over the altenator bracket for rub thru, repair as needed, then put a split piece of heater hose between harness & bracket. Also do icepick trick on # 2,& 7 injector clips, and replace fuel filter every 15 - 20,000 kms.
how many miles is 20,000 kms?? ;)
If yours is an LLY, injector balance rates can show which injector may be bad; if that is the problem. Monitoring fuel return rates is GM's new way of detecting bad injectors on the LB7 motor.
