Duners tunnel polishing "how to"
5.00 star(s)
Took a little longer than planned, but I got this tunnel POLISHED finally.
DUNATIC was kind enough to come up here to Rigby and give me some lessons in the fine "ART" of tunnel polishing!
The master suited up, knowing full well just how dirty this job would be.
Broke out a new wheel and applied a good amount of compound to it.
Then laid into the top of the tunnel to begin with.
One of the things I learned quickly was that I wasn't using NEARLY enough force of the buffing wheel.
Dunatic LEANED INTO IT and put some real force behind the wheel to cut into the tunnel
The flash makes it look like the wheel is stationary, but it is running at MAX RPM and you can see the deflection in the bottom of the wheel.
You can clearly see the polishing marks left behind from the rough cut compound and the stiff wheel.
But even with the rough cut, you can see the gloss begining to show itself.
Now he changes the wheel to a NON-Stitched version and goes to the Pink Jewlers Rouge compound and attacks the whole sled over again.
And again, notice how much deflection there is on the Wheel.
He is LEANING INTO IT hard and getting lots of force behind it.
After the whole sled was done the 2nd time, the final treatment using Mother's Billet Polish by hand begun.
It took a Solid 6 hours with the buffer to get this far.
And if it hadn't been so late might have taken 7 hours to do an even deeper cleaning of the aluminum tunnel.
Apply with the short nap side of a Micro Fiber Towel, buff till it turns DARK BLACK, then wipe off with the long nap side of the Micro Fiber towel. Each time covering a small area so as NOT to allow the polish to dry.
After a couple more hours of me hand polishing the now buffed tunnel, this was my final result tonight.
I can NOT begin to say enough good things about DUNATIC!
He gets very high marks from me for a great job.
If your in the Utah area, he offers his professional polishing services to anyone that is willing to pay his modest fee of $400, which in my opinion is WELL WORTH it considering the time and effort he puts into his work!
Now I am wondering, after all this time and effort, should I go ahead and try a sealent???
ZoopSeal Protective Sealer kit for billet Aluminum
ZoopSeal protects aluminum from the oxidation process, and offers a long lasting, durable shine. Includes video, cleaner, sealer, activator, spray bottle, applicator cloths, finish sealer, metal polish, and tire/trim dressing.
Seal in your shine with these ZoopSeal protective sealer kits. Simply polish your aluminum, stainless steel, or chrome, and then apply ZoopSeal to seal in the shine and protect it against oxidation for two to three years
Thanks for sharing. Tunnel looks awesome:thumb: Wish I was closer, would not have a probably paying him. Great job Dunner and Chris!!!
Many Hours Later and She Just Needs Snow Now
After many hours spent on this project here are the final results. Thanks to Duner and Chris for their post.
Step 2 after white bar
Final Step 3 after Mothers Billet Polish
Now all I need are my parts to come back from the powder coater and I am set to go.
Thanks
Christopher, you say the wheel is running max rpm, how many rpm's? In Duners original write up, he says that the wheel is running at 2000 rpms to get the compound on the pad, but doesnt say if he increases rpm's when applying the wheel to the tunnel.
When he first started in on my tunnel he was running around 2,000 rpm.
And I asked him WHY he was running slow.
He said just because he had always done it that way.
I said crank that bad boy up and lets see what happens.
He rolled his little thumb speed wheel up to 10 and went for it.
The big difference is that the higher speed made a bigger mess as the wheel throws more fuzz and rouge, but the final product looked pretty good to me!
It was alot harder to hold onto at the higher rpm, and I tore up the pad quicker.
shaved a little bit of time off though...
hey Dunatic? did you ever get that PM i sent you???? I sent you another PM, please suggest anything you can think of, or anything i would need!!
Thx
Justin
I was able to come across these products from Canadian tire. Ended up costing me $27 and I'll post the results once i'm finished
Yup, I was talking about you.
I think you did a fine job on that sled.
Enough so that I am considering the same route.
Not sure yet though.
Could go with a Powdercoated tunnel or a polished one.
powdercoat for sure they never usualy wear off or break and hold colr and i would hae my crappy ol powder extreme 600s coated but i dont have a oven large enough :( but im coating the cyliners next week :) candy apple red
