How many sleds can you do with that kit? Thanks.
I see you say you have 8-10 hours in which I don't doubt, but just some food for thought, to cut down on your time per sled you can start out with a different wheel(s). What I do is go down to the Peterbilt or Kenworth dealership and pick up an Orange, Yellow, and White wheels. The orange wheel is your cutting wheel. Cutting a tunnel will take 20 mins with the brown rouge, then I go to the Yellow with brown rouge, then white wheel with either white or blue rouge.
Maybe I just didn't catch the link, but Dunatic was kind enough to point me in the direction of a solution.
http://swmetal.com/
I tried two different buffers and could not get a cutting wheel to mount on either of them.
BUFFER ADAPTER 5/8”
BUFFER ADAPTER 5/8”- FITS BUFF WITH 5/8” HOLE
Without this extension, there is no way to use any of the buffers out there.
the Wheel simply will not mount to them.
Like Mtn Ryder linked.Where did you see this adapter at, I looked on swmetal website but didnt see it. I jsut put the pad on thebuffer without the adapter and it worked just fine, the pad never slipped while I was using it. Ill take a picture of how I had mine set up. I did this because I couldnt find that adapter anywhere. Christopher or Dunatic, where did you see this and where did you order it. I dont see a part# for it either.
I also order some stuff from caswellplating.com and bright-works.com
Swmetal is close and always gets here really fast.
Thunderguyboosted, of you want, we come to Canada all the time, if you want me to get what you want and bring it up, let me know...
That is what I tried.Since I had no adapter at the time I polished my sled, I just improvised. I bought a 5/8" washer from Lowe's, put it on the buffer, put the pad on, and then screwed on the backing nut that came with the buffer, and then tightened it up with 2 crescent wrenches..
But the post on my buffer is SO short, that I could not get the nut to go on after the wheel was in place. Without a proper extension, I couldn't make it work.
I tried to go CHEAP...What kind of buffers are you guys using? I would like to buy one so I don't have to borrow. But the one I borrowed is like a $300 variable speed rig. I don't want or need something that expensive. Any options?
