ducati super moto
soul!
2013 Ducati Hypermotard 821
anythoughts if this would be a good bike for the long track mountian horse or to heavy?
Engine type l-c V-twin
Valve train DOHC, 8v
Displacement 821cc
Bore x stroke 88.0 x 67.5mm
Compression 12.8:1
Fuel system EFI, ride by wire
Clutch Wet, multi-plate slipper
Transmission 6-speed
Claimed horsepower 110.0 bhp @ 9250 rpm
Claimed torque 65.8 lb.-ft. @ 7750 rpm
Frame Tubular-steel trellis
Front suspension Kayaba 43mm fork
Rear suspension Sachs shock with adjustable spring preload and rebound damping
Front brake Dual Brembo four-piston calipers, 320mm discs with ABS
Rear brake Brembo two-piston caliper, 245mm disc with ABS
Front tire 120/70-ZR17 Pirelli Diablo Rosso II
Rear tire 180/55-ZR17 Pirelli Diablo Rosso II
Rake/trail 25.5°/4.1 in.
Seat height 34.2 in.
Wheelbase 59.0 in.
Fuel capacity 4.2 gal.
Claimed curb weight 411 lbs.
Color Dark Stealth Black, Ducati Red
Available Now
Warranty 24 mo., unlimi
Read more: http://www.motorcyclistonline.com/f...ducati_hypermotard/viewall.html#ixzz2T2uqplni
Kind of heavy. I don't know if Timbersled makes a kit for the Ducati. You would probably have to send them the bike.
I haven't even seen any sign of these kits even being put on a machine of this sort . I've seen a few vids of dirt bikes with street engines , so the demand is there . When these kits transfer over to motards , street bikes it will take the game to a whole new level . Yamaha has done it for years and now Cat is sporting that engine . The new bike kit on the block might just have made that connection accessible .
I have the 2013 Ducati Hypermotard SP. It is a phenominal urban cut and thrust bike. I've looked at it for the potential of puting the MH kit on it. There would definately be some custom fabrication to make the rear fit onto the swingarm mount as the exhaust loops down in the immediate area. The motor is awesome though and a huge improvement over the former aircooled 1100 version. With the Termi exhaust it puts out 120 HP. I agree that it would be a bit heavier than the dirtbikes and almost as heavy as a 600 snowhawk. For the money, it would be better to get a 450 MX bike and put a turbo on it. You would then get close to 90-100HP, light set-up and no custom futzing with the MH chassis.
