X
X2Freeride
Exactly what the post title says for sale is a drop and roll chain case will fit edge sleds and Any Pro X or the 05+ IQR as it was built out of an 04 PRO XR case. It has a C and C clear lexane cover. Very slick setup, Also have aluminum dished cover to protect the bottom of the case. Its a little beat up but it still works just fine.
This case worked VERY well on the chassis I had it on, just going a different way with this sled sled, I just dont need it for what I want to do.
Needs bearings and seals, uses same ones as stock.
The titanium steering post is for the Pro X chassis ANY one with under the motor steering. Its a little bit taller than stock maybe 2 inches or so. WORKS EXCELLENT. No bending like the weak stock post. Comes complete with both upper and lower bushings/ bearings pretty much a bolt in deal.
