Driver distances
Kcjepperson
Polaris Klim Kmod BCA
Does anyone know or have the distances between each driver on a 2000 mountain max? The track and the axle aren't meshing at all. I can see where on of the drivers had moved but what to check them all while the shaft is out.
Thanks in advance
Thanks in advance
You might have the wrong drivers for the track that you are using.... What tack is it?
A quick measurement off mine.. distance between drivers from center to center on shaft is just shy of 9.5" You can find all the measurements for driver location on shaft over at the TY forums if you cant find that info here at SW.
I have the 2002 shop manual in PDF. Let me know if you don't have any luck I can look up all the spacing. Iirc the measurements are all from the chain case end of the shaft moving to the left.
With some trial and error we got them back where they go and it everything is installed back in the sled and ready to go
