Looking to install a steel drive shaft from a chain case axys, to one that has the factory belt drive on it, then reinstall the stock belt drive back on it. I'll aso need to change drivers. Can this be done without any problem?
I’m of no help but I DO remember lots of arguing about this back in the day when everyones aluminum shafts were grenading, so be sure to do a lil research.Looking to install a steel drive shaft from a chain case axys, to one that has the factory belt drive on it, then reinstall the stock belt drive back on it. I'll aso need to change drivers. Can this be done without any problem?
i am in the same boat. I have a steel shaft from my SKS. It has 8 tooth 2.86 drivers. I would like to put 7 tooth 3 pitch, or 6 tooth 2.5 pitch drivers on it.
can anyone confirm for sure what lower QD pulley bolt is needed for the steel shaft?
If the shaft cam from a chaincase model, it's an M10X1.25X20 bolt but a 25mm will work. It comes stock with an 8.8 grade, but get one that's 10.9. I buy ARP bolts to use on the QD and have never had a problem.
Here's a link to where I get mine from:
ARP Bolts
Top top pulley takes an M10x1.25x45. I would also upgrade this bolt to a grade 10.9.is that the same size for the top pulley? I can't remember
thanks
