Did timbersled change their chain to a lower strength chain at some point?
I have a new 2022 aro3 premium.
Bought a new 2022 yz450f (left over from 2022 stock) and swapped the kit over to the new bike
Chain link failed the other day (about 3 rides in this season). Had a replacement link but the pins were too thick to fit thru the holes in the chain. Long way out and back in (I was testing riding with ski boots and so had my skis and skins). Brought everything I could including my old chain from my 2016 Mountain Horse (Timbersled). In the end (3.5hrs working on it in the snow) had to use that chain.
I'll look for a chain link that will fit the chain that came with it but it was odd having a different size link (just the pin thickness).
Also I'm still wondering what happened. It's possible the locking pin (whatever it's called) wasn't in the groves on the pins. Could have been ice that pushed it off some how. My other thought is the chain got too tight.
The adjustment uses a bolt to tighten (or loosen) the chain and a lock nut in addition to tightening two bolts as anyone who has a timbersled knows. The locking nut would prevent the chain from getting slacker but what would prevent it from getting tighter (other than the friction by the two side bolts tightened to spec)?
Just trying to make sure it doesn't happen again or is less likely. It was a long day - 7km and 700m climb, 3.5hrs with frozen hands - good times!
