Drippin exhaust
ok, heres the story, pulled buddies 05 900(1600 miles) into shop,had not been started for a couple months, lot of smoke,parked it overnight,next morning puddle or should I say pond underneath belly, reservoir level below supply tube, refilled oil and let it sit for a day. restartd it,lot of smoke but seemed to clear up right before it started spittin oil out the exhaust and puddled again overnight. idles good.throttles good where should i start
OIL
check your oil pump cable make sure its not stuck wide open,also check the fitting that goes in the cases below the manifold.They are known for coming loose and leaking.
Oil pump cable intact?
