B
When I bought my sled the previous owner had the orange (Dexcool) coolant in the sled. The orange coolant isn't as readily available up in the mountains where I keep my sled so I want to drain it and refill with the yellow coolant that the local hardware store caries. My sled is over 5 yrs old and still has the original coolant in it so I'm guessing it's due to be changed. What's the overall consensus on the easiest way to get all the old coolant out? I'm thinking I should try to flush coolant too. The shop manual says to suck it out of the reservoir tank with a vacuum pump. I also read other posts saying to remove the lower hose and just let it drain out through the belly pan. Would this be the hose that goes into the lower heat exchanger on the same side as the muffler and oil tank? How hard is it to pull that hose? Would it make it easier to pull the can out?
