draining antifreeze
04 vertical escape 700. ive looked all over the sled and in the service manual and i cant seem to find a drain plug for the antifreeze. is there even one? or do you just pull a hose and try not to make a mess?
Easiest way ive come up with: syphon what you can from the burp bottle, then remove the upper hose, insert that into a jug of your choice, and use low pressure shop air to force the coolant from the cylinder head backwards through the system and into your jug. Smallest mess system ive come up with.
