Dragon project x
I have a Polaris 700 (99) with a really good motor and was curious of I could put that motor into my 08 dragon 155? I called the local shop and they said that the motor measurements were the same and that the only thing that is different is the motor mounts. Is this possible to do or iOS it a world I don't wanna step into?
Yep get ahold of Brad at Power Addiction Racing or he's 1200 PSI on here. He makes a motor plate to do the swap.
dragon
Need carb boots from a 04 pro x I can get a # if you need, have to notch the chassis for oil pump, the pipe is tough I'm modifying a dyno port single, belt from an f7
i thought the motor mount would take of having to knoch the chassi. i did talk to brad and he said that all i would need is to put boots on the carbs, and get a wiring harness from a 2006 600r and that everything would plug right into the pig tails. is there anything else you could tell me about this? than you much for all the info you have given me
Interested in doing the swap as well. I picked-up a complete 2008 Dragon RMK 700 rolling chassis that is just waiting for an engine to go into. I am leaning towards finding a 700 Liberty Big Block w/ PERC and figured it would do quite nicely in there. I plan to pick up Brad's engine plate so if anyone can share their input into the swap I would greatly appreciate it! THANKS!
When i cut the chassis near the oil pump does it compromise the strength of anything? Or is it something that is a quick 5 min cut? Does anyone have a picture that I could see? I appreciate all the input
