Dragon Issues
M
Oct 2, 2022
2
MB
I have a 2010 Dragon 800 switchback that died on me last winter. I had just put a new cylinder and piston kit in after losing a ring. Ran great for about 3hr.s then it felt like I blew another jug, loss of power, running rough, running on one cyl. and the gauge cluster went out. Thinking it was a cyl/piston issue I pulled it apart. No issues, still looked new. Got it back together, and now Im at a bit of a loss as to where to start looking. Bad ecu/ground? Help much appreciated.
retiredpop
1,351
296
83
Calgary
First thing comes to mind is a bad voltage regulator. Does it fire up and run normal for a while after sitting a few minutes?
Look at the back of the ECU to see if there is any bubbling or indications of excessive heat.
M
Oct 2, 2022
2
MB
Nothing obvious on the back of the ECU. Went through the volt reg/rect diode check from the book and just about everything is reading lower than the spec. range. So too much voltage?
Thank you for the help.
C
Jan 21, 2023
1
Ontario
I had something similar happen I was riding slow just got it out of the shop for the first time it worked fine but once I took it out for about 10 minutes the gages and lights went out then bogged out when I go to start it the plugs get wet and it has lots of spark but still won’t start unless I put gas down the plugs but will still big out unless at a high rpm ,don’t know what to do
