Dragon 800 elec start pics
Any pics would help just something with the battery box mounting and the starter mounting location.
Thanks
Bret
Battery box mounts under the secondary clutch. There are two pre-drilled holes in the belly pan to attach the bottom of the battery box to belly pan.
You need to drill out a couple of rivets and attach the new bracket at the aft end of the battery box.
The starter motor is attached to the pre-drilled holes in the bulkhead (at an angle) under the exhaust pipe, just fwd of the y-pipe.
The must challenging part is attaching the pinion bracket under the left cylinder of the y-pipe.
Route wires around and behind the airbox to electrical connection aft of clutch cover.
Thanks guys I pretty much have it back together now except the battery box everything else is exactly like you said.
I would take a picture or two of the battery box installed just to be sure it's right.
Thanks guys
