DOES THE BASE MODEL RMK MAKE A BETTER TURBO CANDIDATE?
IMO... I think it would.
The PRO has better base shocks than the Base, A lightweight Brake Rotor, A tubular Jackshaft, a plate style Steering post top, Pro Taper bars, a non ported snowflap and a carbon fiber rear bumper tube. No bulkhead/tunnel heat exchanger.
The tracks on the PRO and Std are the same this year... both are single ply series 5.1, 2.4" lug height tracks.
The base model 2011 PRO-Chassis RMK has the base model Arvin-Meritor shocks... Most turbo guys with the ski lift issues are changing these out anyway...
Lightweight brake Rotor and Jack shaft... saves about 3 lbs... but the Tublar PRO-RMK Jackshaft may or may not be able to take a years worth of 100 more HP of the Turbo... Plus, you can buy and install the sawtooth rotor in minutes if you really needed it.
The steering post... I prefer the pivot style steering post top "T-Top" posts, but it is heavier compared to the Pro-Taper setup... The Pro-tapers are too tall for me and from what I hear... too tall for people like Chris Burandt as well....The pivot seems to give a bit more in crashes (I do a fair share) than the plate style.
The snow flap.... hmmm
The CF Bumper Tube on the PRO.... not much lighter than the Aluminum if any...
NOW... For the big advantage...The Standard 2011 800 RMK's have a bulkhead heat exchanger... Very useful if you are going to a water to air intercooler which seems to be popular and maybe getting more so. Plus this will add some additional cooling. This heat exchanger will NOT be available as a service part (you cant walk into your dealer and buy the part) from what I learned from the Polaris staff in Roseau on Tuesday.
If you are turbo and modding the sled anyway...you will probably go with a suspension upgrade that will control the front end lift with the 100+ more hp than the stock configuration.
