Hey Guys,
I'm not finding much info or resolve on the internet about my issue. I have a 23 backcountry sport with the 600efi that cuts out after about an hour of riding. It'll run if you just barely give it throttle but then will cut out if you give it anymore (just like a TSS is kicking in). Its for sure getting fuel, so the only thing I can come up with is that its a tsp issue. Now, when I look up the oem part, it shows that the TPS is not available and you have to purchase the whole throttle body assembly. It doesn't even have a part number for the TPS. But if you look up a 22 600efi, it has the TPS available. Does anyone know if anything changed from the 22 to the 23 600efi that would prevent the 22 TPS from working? And then lastly, will I have to sync the TPS at the dealer, or is there a way to calibrate it. Or has anyone had this issue before?
