Dobeck Gen4 AFR+ Issue
I'm hoping I can get some advice on an issue with my AFR+. Details-2014 KTM 500XCW with 610 kit. Green @ 12, Yellow @ 13.5, Red @ 12.8, Green-Blue @ 12.5, Yellow-Blue @ 11, Red-Blue @ 11. The issue-I can't get it into the red zone, even on long full throttle pulls. It just sits in the Red-Blue transition. Any advice is appreciated.
Set Yellow Blue to max (lean) and Red Blue to min (rich). This will fix your problem and you will transition from green almost directly to red.
yea what rush said. Make sure your yellow blue is a higher number than your red blue. Example yellow/blue=14 Red/blue=11
Rush44, how do these two fueller controls differ?
Yellow/Blue and Red/Blue are basically set load requirements to enter each mode. Max lean is LOTS of load to enter a mode, Max Rich is LEAST amount of load to enter a mode. So set your Yellow/Blue to max lean (hard to enter mode) and Red/Blue to min rich (easy to enter mode). This will allow you to pretty much shoot by Yellow and go straight to Red.
