Dobeck Gen 4 Numbers
gen 4 dobeck
thx for the reply v 1200 , was out yesterday trying to get numbers dialed
Talked with dobech tech today, now i have a better understanding how this system works.
Thought with changing altitude, temp were a factor but only for the green at idle as this is the only open loop running off stock ecm.
Basically, i can input the numbers in while in the garage
They are preset green 13 yellow13.4 red 12.8
green/blue 11.8 yellow/blue 11.8 red/blue 11.8
going to set my numbers at g12.5 y 12.8 r 12.5
g/b 12.5 y/b 11.8 or slightly lower r/b 11.8 or slightly lower
This is the information from dobeck tech today
Anbody care to add info please do thx
2014 ktm 450 sxf
green set accordingly to your idle when bike is at operating temps. keep the needle between 12.5-12.8.
yellow doesn't really matter 13.0 is fine
red on my bike I set at 13.0 tested a few other numbers and this seems to be best!
your green/blue is your accel. pump for fuel left mine at 13.0 (stock)
yellow/blue doesn't matter just set it above your red/blue
red/blue set it down to like 12.0 just make sure it is below your yellow/blue (for example: yellow/ blue 12.5 and red/blue 12.0)
I usually fatten the accel pump setting a tick or two to deliver a small shot of extra fuel during load changes.
