So thought of adding a extra heavy duty clutch spring from a Kawasaki klx110 to waste gate actuator arm and have it push against the internal spring that is currently 7lbs. Want to be able to turn boost down as far as 3lbs @1500k ft. so on a longer trail rip at home want to have enough fuel to make it from bar to bar and will have to run on 91 non oxy at times.
I tested this on bench and could almost take all pressure off waste gate and apply all pressure back (7 lb spring inside actuator) by loosening the spring in pic.
I was not comfortable tying into the center section of my pipe to trick waste gate into thinking the machine was running higher boost than actually was (Gus)
and didn't want to drop another $80 for a 4lb actuator.
I'm trying to see if I can build a low elev turbo trail ripper that will run good.
What do you guys think? I know most people run at high elevation on here but maybe some one from ak will have some info? Thanks in advance.
