I'm probably going to be putting on a wrap and don't want to have to take away from the wrap with the addition of vents.
Do I need the vents if I'm just adding the pipe and can? Any consequences for not adding the vents?
Thanks
No vents needed.
Ever.
They don't actually do anything except look bad.
100% accurate. Buddy did some testing with fans. Said the vents didnt do anything.
Interesting, I assume he took basic under hood temps?
It would be interesting to see actual clutch temps compared between sleds set up the same and driven in the same conditions by the same rider.
I agree, they are not "needed" but it is an interesting topic. I ran Mo Flow side vents on two of my previous Pros. The vents were the bigger side vents that are almost beside the can on side and the secondary clutch on the other side. I bring this up because of previous observations with these vents.
While I never actually took under hood temps or clutch temps....my bad! I think they do assist with some cooling. I say this for two reasons, first my two Pros I ran never ever had belt or clutch issues and upon stopping at times, you could see the heat escaping from the sled through the vents. There would be very little snow or ice in this area and you could feel the heat coming out sometimes. Where the holes were cut in the panel, you could see small pieces of ice and sometimes water on the vent material because of the heat escaping.
You would think that if you can see the heat escaping from one sled while stopped and the same sled beside it is not doing this, cooling is occurring at a faster rate. Now change to riding, one would think that this would still be occurring and in theory the vented sled should not be building heat has fast????
Again, I'm not saying that vents are "needed" but in theory, they should do something??????
The other test is.........roll your windows part way down on your next trip during the winter.......I'm guessing the interior will be a little cooler??? ha ha.
The only time you ever need vents on these sleds is on a DEEP powder day. Then . . .guess what . .the vents are covered with powder! The only type of venting that works when you need it is something like the "blowhole" or other forced ventilation. All the others are a waste of money, IMO.
Then add in the fact if you were to use a shock tower type vent. You would think air would now be moving in, creating air circulation, and escaping out a side vent.
While I don't think they are as effective as some may seem, I do think placement of vents is the crucial component to making them actually work.
That's what I thought until I tried a blowhole like setup and it made zero difference in clutch temps. (Marine grade bilge fan)
A small adjustment in clutch calibration to fit your riding style is worth 5 times what a blowhole can do.
