Disconnect keyed ignition switch on 13?
likkerpig
Did a bunch of searches, it's late and I'm tired.
Want to disconnect the keyed ignition switch and just run the kill switch and tether. Keys are pointless in my mind.
Which wires do I pull to do this? Just a standard pull start 13 pro.
Thanks in advance.
Instead of removing the switch/unplugging it...you might try this:
put the key in the switch half way in and turn it on...then remove the key. The key switch stays on and you dont have a key to worry about losing.
:present:
Or just break the key off in the switch. You can still turn it with your finger if needed and it doesn't cut the crap out of you when you are all over the sled, especially where they put them on the old wedges. For resale you can get it out with a pick and sell it with the spare.
You can simply remove the key switch and leave the connector dangling.
The DG/W is the starter lock out (unused by you) (tells the ECU when the starter is activated)
The White is start solenoid cotrol ground
The Black is the Hard stop to the splice with the kill and tether
The Bk/DB is the sensor ground splice to all the kill devices including the soft stop.
