Diffrens between the Mtn tammer skids..?
Y
Yamaha_nisse
Hi,
I'm havin' thoughts of buyin' a MTN tammer for my Yamaha Mountain Max 700..
I've been lookin' in some threads and on their website. But I can't see the diffrens between the suspensions.
For example, what's the difference between a M-series MTN Tammer and a APEX MTN tammer?
Because I've seen a few used skids with a great price.. So if I buy a used MTN Tammer that is manufactured to fit in a M-series will It fit on for example NYTRO rails?
Hope u get what I'm tryin' to ask..?
Cheers Rasmus
it is all about the geometry (angles) not all have hte same angles and pieces lengths...
give Allen @ timbersled a call, he will help even if you are trying to locate in the used category...as it helps him if even used they have good value...
Thanks, it was the answer I was looking for. ;)
Or one more thing, How will a MTN Tammer NYTRO skid fit on the NYTRO rails?
Have a friend who thinks I should buy ICEAGE rails instead, but I don't see any purpose in that?
it's easier to use iceage rails as they are premade for the mtn tamer skid. with your stock rails u gotta cut and drill
Hi,
Cheers Rasmus
Apex or Nytro will fit your Mtn. Max, Cat will not work. If your looking for a used one call me on Monday. Thanks, Budd
P.S. Budd works at Timbersled Corporate Headquarters, and their phone # is
(208) 255-5644
Yer welcome Bud;)
You have to cut the rear suspension mounting tab off of the rails, and install a new tab provided with the kit... at least on the nytro - yer sled may be different. Give Budd a call.
there is a really really easy installation description done on TY here is link...
it is not that difficult to cut yours...I did that, then went to longer track and bought the IceAge...
Here are pics of both skids...
Here are stock rails with the cut done to them (you can see the bolts on teh back end)
them installed...
Here is the IceAge Rails...
