Different Fuel Plugs..
NapaMatt
Matryx 850 Pow Slayer!
Polaris Klim Timbersled BCA
ok.. So be watching and reading all year.. waiting for this topic to come up.. and it hasn't so.. i guess i'll Start it..
K we all know that the Pro Comes with 2 different Plugs
One for 91+ non eth.. which is 160 ohms
a 87+ with eth.. is 24 ohms
SO hears the deal.. The Difference is only 5% Fuel Change between the 24 Ohms, and the 160 Ohms..
??? Is has one played with like a 100 Ohms Resistor? or a 200 Ohms??
Thinking this way is cheap to play with the fuel curve that a PC-V thats 329$$
So why not play with .10 resistors??? hmmm
Anyone any thoughts????
I want Postive thinkin !!!! geez
yes i know the bad things can happend!
The biggest advantage of fuel controllers is being able to fine tune specific rpm ranges.
Matt, I think your on to something but as murph said the fuel controler adds and subtracts the fuel in specific locations. I think with a little more R&D you could really have something. I will be waiting to hear the results, because my pro is still in the mail until next fall.
I would imagine that the ecm is looking for a high/low resistance fuel plug to pick between two maps, a resistor inbetween would probably just set a code and not partially change a fuel map. I changed my fuel plugs in the dark once with the engine running and it set a code for a bad resistor. So Im guessing anything but OE resistance is gonna cause problems and failsafe to ethenol fuel map.
i agree ..well said...
most likey the "ecu is looking for 2 values, and only 2. The fact that polaris printed these values(ohm) on the "plug" is only for reference.
In the same respect, I have noticed polaris tends to print/label connections and values on thier vehicles. THANK YOU POO!
Other, manu's dont label crap and thats VERY frustrating, imo!
It will only take the 160ohm or the 24ohms resistors.
