Hi; Wondering if anybody knows the differences, if any, between the actual chassis on the axys model and the pro ride chassis. Other than the obvious raised chassis, both sled chassis look identical.
The handling is better because the chassis is taller. Same thing happened when we raised the Mod sleds with taller front end and extended case., The Pro sits lower which resist tipping.They may look similar but they are not even close to the same sled.
The axys is 95% NEW/Different from the Pro. Basically the footwell hoops and running boards and crappy rear bumper are the same and thats it. They aren't even close in handling, power, ride, and feel.
And that is where Polaris Marketing is struggling the most to get people on the axys. People look at the axys and pro as the same sled with a different motor. Just like the OP in this thread. The sleds are worlds apart even if they look similar.
I was wondering if the tunnel design on the two were the same but just raised on the 2016.
I haven't looked but does anyone know if they changed or upgraded the steering block bushings to improve the steering slop you end up with??? I ended up throwing a set of OFT steering blocks in my Pro and what a difference !!!
