differences between Nytro XTX and MTX?
Snowfix
Thinking about snowchecking the XTX instead of the MTX and turning it into a hillclimber. I would change the tunnel, track, handlebars, and suspension anyway. This way I get the redesigned wider front end, better shocks, and even a little bit cheaper.
Am I missing something? Less front drive shaft clearance? ECU? etc
Xtx -mtx
I took short track and made it into long track and it was ok but had to do some tuning on suspension.
I rode the new XTX and wow what a nice ride.
New valving in shocks and they moved the ski bolt ahead about 1/2" to get rid of nervous steering. I drove across a tracked up rough hill and it goes through it without jaring your pickle like my short track.
Shocks and springs sure make a sled.
http://www.powderlites.com
Xtx
Just drove both of them yesterday (09's) and the XTX is awesome. The MTX felt better than the 08 model with the new spring steup on the front shocks( on the trails going out to the hills). I would go for the XTX with what you are going to do. My .02!!
:D
:D
I had to make the same decision and if you are already doing a rear suspension and tunnel, the XTX has a lot better front end and is cheaper, so that is what I would do. I am going with the XTX, since I am taking off the tunnel, track and rear skid and I am going to keep the front suspension.
Will The Xtx Front Shock Work With The Timbersled Narrower Front Suspension Or Are They To Long... I Like The Better Shocks But Am Not A Fan Of The Wide Stance Thanks
