difference in motors
rmkelvis
New member
Is there any significant in the motors between an 07 700 dragon and an 08 700 dragon? or the chasis?
2007 700 vs. 2008 700
I think maybe different number of injectors? 07 has 2, 08 has 4. Not sure.
Not true.
4 injectors on both. 2007-2010 700's ALL have 4 injectors.
Difference is the existence of the de-compression valves on the 2008's,
No de-compression on the 2007's
Fuel map is RICHER on the 2008's
2008's have the "Ethanol wires" that when plugged in provide a 5% LEANER fuel curve.
2007 700's DO NOT have the Ethanol wires.
2 CFI's injectors are used on
2011 800's
2010-2011 600 RUSH
2009 +/- SHIFT 600
I just rebuilt my 09 700 RMK and if it has more than 2 injectors I couldn't find them. I thought that all 700 only had 2 injectors.
Mountainhorse-Great Point! Just top-end! but I took off my throttle body and I don't remember a fuel rail or injectors below them- but I have been wrong way more than once! Thanks-
Just looked at online parts- and you are correct the other set of injectors are below intake boot- hard to see!
