difference between IQ and Pro spindles
I'm pretty sure the ski mounting sizes stayed the same between the two.
they will swap out no problem. the tie rod end mounts in the bottom of the iq spindle and it mounts to the top of the pro spindle. i put pro spindles on my 10 800 rmk.
The Bushing for the Ski Bolt is Different...
But u can use a IQ one in the Pro Spindle or Vise Versa
Correction, the Pro uses a metric ski bolt that is slightly larger than the 3/8 standard bolt used by the IQ. If you use the Pro spindle you should use the IQ bushing for the IQ ski bolts, or use the Pro ski bushing with the correct metric bolt. I believe it's a m12x1.5.
The same is said for the ball joint bolt.
