Difference 700 cylinders??
Norway
1,978
476
83
50
So , what is the difference in the cylinders offered for this 700 twin?
I found 420923690 and 420923695, with only a mention of cylinder studs and a decompression hole or something?
Don't care about those to things really. Just wondering if porting differs, or you could swap them around as you want.
Thanks,
RS
T
Sep 1, 2009
82
54
18
a 923690 cylinder is from the '99-'00 sand cast engine and does not swap with a the rest of the 700 cylinders. It uses smaller mounting bolts and different cylinder bolt spacing.
a 923692 and 923695 have the same porting, the only difference is the 692 cylinder has the decompression notch.
