dies like it’s out of fuel...at full tank
Yesterday I was riding my 2011 m8 sno pro and it died as if it were out of gas. It still had about half a tank of gas so I was a bit unsure of what the problem was. I had a gallon of gas with me so I put it in the tank and it ran good for 3-4 miles but died again. It would start and maybe run for fifty yards but would start to idle high and then proceed to die. Went back today with five gallons of gas and was able to get it out. Still cut out and died a few times though. Initially I thought it was a a problem with the fuel pickup line but I no longer believe that to be the problem because the tank it completely full of gas. Maybe a wiring issue or a sensor? Thanks for the help
Yes, I have personally seen a few times when that pump failed. Similar deal...they fail slowly and don't provide enough pressure. You can check the wiring, but if it is working at all, unlikely it is wiring...more likely the pump is going bad. Also, make sure your tank breather is not clogged...that'll do it too after running for a bit.
Check where the two wires go into the tank, through the brass fitting. I just fixed a couple wires on an 08 M8 last week, which had worn through against the brass fitting.
I replaced the fuel pump and took it out last weekend and the sled ran great.
Good deal. Yeah, those M series fuel pumps fail in weird ways...can really mess with you.
Update: several problem free rides after replacing the fuel pump the sled started having what seems to be the same issue. It died three times and two of those times it started up after a minute but the last time it would not start again until I got it home. I really have no idea now what is wrong. It seems to me that it’s some kind of fuel system issue because it will usually start to rev higher and kind of skip and cut out and then die. Could it be an electrical short or something like that? Any ideas are a big help. Thanks
Check for pump grounding or wire connection issues...makes sure electrical connections are good with harness, etc. Also, might check your voltage regulator and make sure you aren't sending too much voltage to the pump and damaging it. Also, do you have headlights? Some in that era would produce too much power without headlights, causing other issues.
Just had the exact same issue with my M8 a few weeks ago. Ground wire was worn through the insulation at the brass fitting. Recoated the wire with liquid tape and added wire loom to prevent it from happening again.
Sent from my SM-G935V using Tapatalk
Is that the two wires that run from the fuel pump out of the tank?
Does anyone know what this is?
Okay. I noticed that where the wire is connected to the nut looking metal piece, it was bent had a crack and might not have a good connection. Could that somehow cause the problem that I am having?
