Z zr870 New member Lifetime Membership Dec 13, 2014 #1 Does anyone out there know the torque spec on the 5/8 bolt that holds DD from inside the shaft....70 ft lbs...or 120,,,,2010 M8
Z zr870 New member Lifetime Membership Dec 13, 2014 #3 RACINSTATION said: Blue loctite #243 and 70 ft/lbs Click to expand... Thanks bro
Rixster Well-known member Premium Member Dec 15, 2014 #4 70 FT LBS ? WOW is that a cat spec? I would have never guessed they would put that much pressure on a self tapping sheet metal screw. I changed all mine out to a fully threaded bolt and feel much better about getting those nice and tight.
RACINSTATION Well-known member Lifetime Membership Dec 15, 2014 #5 It is not a self tapping sheet metal screw. It is the bolt that is in the center of the driveshaft and holds the shaft onto the Diamond Drive. It has blue loctite on it when you pull it out.
