K
Kyle91rs
Last week in Revy I was riding my proclimb 800 turbo, and I was having detonation issues. I was running 50/50 112 rg/pump gas at 10psi. So the next day I ran straight 112 rg and still had a couple det codes (ecu21) on the display. My plugs looked fine, my afr was normal, the sled didn't bog out or fall on it's face, my knock sensor is tight in the head, I don't understand... Should I be worried about this? I'm running a stage 2 ovs hot side, boondocker intercooled cold side, rktek turbo head and a boost it box. I'm gonna change my plugs and maybe take my knock sensor out and reseat it in the head, and run straight 112 again. See if that does anything. Is there any other little things I should check for that could cause detonation codes??
