Do you know where the tabs are on it? Sides or top?Last time I hit a tree and mine came off it appeared to only have tabs on the sides holding it on. It immediately went back in when I grabbed it and pushed it back in.
Can you do it by reaching underneath the magnetic glove boxTabs are on sides. Going to fix mine as well. Just acquired an 18 Mountain Cat and it drives me nuts.
So you have to push the tabs in between where the holes are. And do the have to be pushed inward from the outside?
K And can I just reach under with my fingers or will I have to take the 4 screws out on the top hood/windshield piecePush tabs in from outside.
Just reach under.. I put silicone around mine and put it back.. silent and still nowK And can I just reach under with my fingers or will I have to take the 4 screws out on the top hood/windshield piece
I did get it out. I wasn’t pressing in the right spot before. We may adhesive foam we have and sandwich it in thereJust reach under.. I put silicone around mine and put it back.. silent and still now
Do you just put it on the the edge of the plastic circle that thing clips into then?Just reach under.. I put silicone around mine and put it back.. silent and still now
I put it on the gauge side, but yeah.. just to make it a little thicker so the clips hold it in properly..Do you just put it on the the edge of the plastic circle that thing clips into then?
Ok gotcha thanks i can see where it kinda rubs may just put it thereI put it on the gauge side, but yeah.. just to make it a little thicker so the clips hold it in properly..
