T
trestlecreek
So, on the pro, are you suppose to put two washers (one each side of the spring ) on the secondary, and primary? Or just the secondary???
What's the scoop with the aftermarket washers?
They are a white slippery plastic washer and they prevent the secondary spring from binding..
Worth it?
You can buy them thru SLP, WPS is on backorder. Also, I spoke with someone at SLP when I ordered mine. He said you only put 1 washer in the secondary, between the cup and helix... None on either end of the spring. There is so much pressure on the spring ends, that it just chews up the delron washer and doesnt do any good. My question is, does the washer go on top of the circlip that holds the cup down? I havent opened my secondary up yet and trying to visualize all of this...
