On all my previous sleds from '97 to '07 I would just unplug the keyswitch, tape up the connector and throw it on the shelf until it was time to sell the sled. Any reason why I can't do the same when I buy a '14. (I won't be getting electric start)
a boost gauge for your turbo!!!
Would be a tiny boost gauge!
I think I have it figured out though. Gonna put a 12v USB charging port right there. Found one already with a waterproof cover for both closing it when not in use and for when you have something plugged in. That way I can charge my phone and a GPS at the same time if I need. Will be more of an emergency thing than something that will get used all the time. Just need to verify the size.
So once the switch is removed, does anyone have any recommendations on what to put in its place to cover the hole?
Gorilla tape
You can use a knockout hole plug. Normally used to plug an empty hole in an electric panel or switch box. You can get them at any hardware store. I moved my switch inside my defroster bag and plugged the old hole with one. I Plastic Dipped it black first.
Sent from my DROID RAZR using Tapatalk
I went down to home depot, and got an electrical hole plug 7/8", then painted it black. works well and just .59
If you go to a true hardware store such as Ace or True Value they've got those little bins full of specialty parts in the nuts and bolts section. Usually there is a variety of black plastic hole plugs that just snap in.
