dd oil change
I have an 06 and 07 I changed the oil in the dd and is there a better way to drain the oil to were its not making a mess in the belly pan under the secondary. I havent done the 06 but I think it drains on the track side?
I just tipped my 07 up on its side after removing the side panel to drain my DD oil. The mess I just mopped up with a butt-load of blue towels and brake cleen
i just put a bucket under the holes were the secondary is in the belly pan it wasnt bad but I thought there has to be and easier way than getting oil in the belly pan.
I just tip it and take the outside half off. This way I can pull out what gears I can and soak up all the oil. Then put the new oil in and bolt the cover back on. This way I get to inspect my gears and bearings very closly. More peace of mind for myself.:rolleyes:
